I'm playing on a relatively new (8 months) Fender Supersonic 1x12 and using the fx loop. Recently, I've found when I tilt the amp back (it comes with the legs so it is supposed to be able to do this) the volume drops to barely audible, but only if I am using the fx loop. If I disconnect the fx loop, volume goes back to normal. If I tilt the amp back to standing upright, everything is fine also. I've opened her up and searched for a loose wire that is shorting or not making a connection as a result of gravity when the amp is tilted, no luck so far.
Does anyone have a suggestion of what to look at more closely? DO tubes get weirded out by tilitng them backwards a bit?
Thanks in advance, Nick
