Hi everyone,
Decided to revisit this one so I can unload it. Issues are low volume, very dark sounding, distortion (but kot unpleasant), cathode voltages in preamp & PI are high, and PI plates are low. Power supply amd power amp check out fine, all resistors checked okay, out of circuit if needed. Replaced most of the coupling caps (none in trem yet). All lytics replaced. Tubes are a good pair of 7591As and preamp tubes are 6C10, not 6BK11.
Schemo here:
http://tubeamplifierparts.com/schema..._schematic.gif
Voltages for preamp tubes, separated by section:
V1
Pin 4: 1.35V
Pin 9: -.6 to +.6V
Pin 10: 75 to 125V
Pin 6: 3.2V
Pin 7: -.35V
Pin 5: .35V
Pin 3: .36V
Pin 11: -.35V
Pin 2: 0V
V2
Pin 4: 3.44V
Pin 9: .3V
Pin 10: 163V
Pin 6: 2.2V
Pin 7: 0V
Pin 5: 150V
Pin 3: 2.0V
Pin 11: .03V
Pin 2: 126V
Also, power tubes G1 showing .03V, but all others spot on within 10%. Right now my main concern is V2. Any suggestions? Thanks!
Justin
Schemo here:
V1
Pin 4: 1.35V
Pin 9: -.6 to +.6V
Pin 10: 75 to 125V
Pin 6: 3.2V
Pin 7: -.35V
Pin 5: .35V
Pin 3: .36V
Pin 11: -.35V
Pin 2: 0V
V2
Pin 4: 3.44V
Pin 9: .3V
Pin 10: 163V
Pin 6: 2.2V
Pin 7: 0V
Pin 5: 150V
Pin 3: 2.0V
Pin 11: .03V
Pin 2: 126V
Justin
