So I just replaced all four blown TDA7293's.
Powered amp up without those boards connected and everything looks okay.
The caps and traces on the 4 output boards are good.
Before I reinstall the boards and test:
The heatsinks are hot, stay away from those.
No grounding of speaker output ground, otherwise it'll just blow up again.
The amp has a "load protection" circuit.....guess it doesn't work too well.
I was thinking of insulating the rear pins of the 7293's with shrink tubing to prevent possible arcing which may contribute to failures, but why bother.
