Originally posted by Jonny toetags
View Post
70's Ampeg V2: need some maintenance help
Thanks guys....it's been going great!
I ended up changing the tagboard while i was at it. Good thing I did: it crumbled when i removed it.
I've also been resoldering suspicious connections.
I'm going to tackle the boards now:
http://privatepollution.com/images/Ampeg/board2.jpg
http://privatepollution.com/images/Ampeg/board1.jpg
I'm going to change those 2 white .47 caps.
Should I change the little greenish blue ones (besides the 2 .33's)?
Also, I noticed some resistors were sitting really high off the board....is that normal?
How would you guys hook up the bias trim pot so it's accessible without removing the top panel? Should i go trim pot or std 16mm.Last edited by Jonny toetags; 09-21-2013, 07:33 PM.
Those 2 board pictures you posted are both the same (board 1 jpg not there).
Yes it's normal for some resistors to be raised off the board (keeps heat off board).
What is your concern with the white caps? Looks like a cosmetic issue as they both seem to have the same dark spot.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g-one View PostThose 2 board pictures you posted are both the same (board 1 jpg not there).
Looking at them I'm just trying to prevent anything from failing.
I am just adding some general info to it.
Gnardos comments have been quite good, but never use a tubeamp without a load, regardless if it is a loudspeaker or a load resistor.The output tubes are only stressed if the transformer is shortened on the secondary, but if the transformer is open and you play it....it'll die.That can become very costly. I even hook up a load resistor for just static measurements.That's why some manufacturers have the outputs shortened to GND via the output jacks, just to help you not blowing up your amp, but that doesn't mean that you should test it that way...
A cathode resistor is not only current sensing, it also tells you straight away if the tube works or not, also a 10 Ohm resistor in each cathode sounds much more cleaner and lengthens the tube life. Arr, there is a small disadvantage, it will be a little bit less power in the output but I think it's well worth it.
And last not least, the golden rule number one: Always have one hand in your pocket when you measure tubeamps. For your own safety!
I got sidetracked with a few other projects and sat down with the V2 again.
Here's my issue:
-Power works fine (power/stdby), but when i switch the amp off standby (play mode), I get a humming/popping, that slowly gets louder and louder. This happens with the volumes at 0 and no guitar connected.
The only other mods i've done so far (besides ground plug, which is wired exactly like this) are changing are the small electrolytic caps on the circuit board and replacing the two .33's to a couple .22's (yellows in this pic)
v2board
Edit: It sounds like this: http://www.youtube.com/watch?v=-CBJSzC88Lg
Update: I just powered the amp on with no preamp tubes then slowly put them back one by one...now it seems to work fine.
I'd still like to know what could have caused that. Weird.Last edited by Jonny toetags; 10-23-2013, 03:38 AM.
Originally posted by Jonny toetags View PostUpdate: I just powered the amp on with no preamp tubes then slowly put them back one by one...now it seems to work fine.
Having been fooled many a time about finding the root cause of noise in a tube amp, don't be surprised if the crackling and hissing comes back. Removing and replacing a tube socket on a PC board is not a task that I envy.
Removing and re-inserting the preamp tubes may have scraped the connections clean of oxide as mentioned by Aloha Mark.
Should the problem come back, check the solder the board mounted sockets, it is not uncommon for these V series amps to need resoldering of the sockets. In such cases wiggling the preamp tubes will sometimes offer a temporary "cure".Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
The new stuff is called DeOxit Gold so the OP was sorta correct. If the sockets/pins are cruddy, I use a non-residue contact cleaner first, then treat the tube pins with the DeOxit Gold. I'm afraid that on some tube pins regular DeOxit may turn to a semi-insulating varnish; IIRC, it's rated at 100C. I actually called Caig when ProGold changed to DeOxit Gold and asked about the temperature rating and was told that although it's lower than ProGold, it's rated at 200C and is fine for tube pins. I have a few of the pens around here, and every amp I work on gets treated.
