I am working on a Kustom Lead I guitar amp. PC boards are as follows:
PC 5129
PC 5033-01 Rev 0
PC 5131-01 Rev 0
Here's an overview of the the three boards:
When it came to me it was blowing fuses immediately when powered on. Someone had spliced in an inline fuse holder, which had fallen apart (see photo).
I traced the short to two small diodes on PC 5131. They were both shorted. I couldn’t find a schematic for PC 5131 to determine the value of the diodes, so I replaced them for the time being with two 1N4007 diodes I had on hand (see photo).
I powered the amp up on a light bulb limiter and the bulb stays off and it has stopped blowing fuses. The amp plays but the reverb, tremolo and pull-bright functions are not working. The controls have no effect on the sound. I can tap the reverb pan and get a “crash” sound, but no reverb effect when playing through the amp. I don’t have the footswitch for this amp, so I can’t see whether switching it in and out makes any difference. I tried using a standard Peavey two-button (“reverb,” “select/effects“) footswitch and it made no difference. With respect to the pull-bright function, the switch itself works.
My questions are:
Should the tremolo and reverb effects work with no footswitch attached?
Should the Peavey footswitch work with this amp?
Is there any part in particular that the failure of those diodes might have ruined?
Any other ideas as to a likely suspect for the faults?
Does anyone have the schematic for PC 5131?
Are those 1N4007 diodes suitable permanent replacements?
What value fuse should I be using (the sticker near the fuse holder says “REPLACE WITH SAME TYPE 1 ½ SB AMP 125 VOLTS.” Does that mean replace with one ½ amp fuse, or replace with a 1 ½ amp fuse?)
Thanks for your help.
John
PC 5129
PC 5033-01 Rev 0
PC 5131-01 Rev 0
My questions are:
John
