I've got a hot rod deville here that is acting strangely. The clean channel seems to break up a little early, and when you really crank it the distortion has a strong crossover sound to it that varies with amplitude that's not present at lower volumes.
I've tried swapping out power and preamp tubes to no avail, and the voltages on all the plates are within a few volts of what I'd expect.
The only real positive clue I have is something I can't make anything of. There's a small buzzing sound inside the chassis when the amp is on. It stays at about the same volume level whatever the rest of the amp is doing. I can't identify exactly where it's coming from, but it's definitely from some component on the interior of the amp.
I'd be much thankful if anyone can help out with this. For this evening, at least, I'm out of ideas.
