I'm going in circles on a Fender Bandmaster AB763. The basic symptom is that it distorts way before you reach max power and output is low. The schematic is HERE
Here's what I know.
1) Tubes are new and I've subbed several know working sets.
2) Electrolytic caps have been recently replaced and tube voltages are normal.
3) 5V p-p on the output tube grids gets you .5V at the speaker.
4) At 6V p-p at the speaker, you start to see distortion on the top half of the waveform (looks like crossover distortion, but is closer to the peak on the leading edge).
5) At 12V p-p (on speaker jack), clipping starts.
6) I can run the input up substantially higher and still get no distortion or clipping on the grids of the output tubes, so I'm certain the problem is in the output section.
7) OT resistance readings are 100 ohm red-blue, 65 ohm red-brown, and about .5 on secondary.
8) The transformer is stamped P-TF22848 and looks to be a replacement.
9) Screen resistors are new (one was burnt and the other out of tolerance originally).
10) Bias voltage and current are fine- both measured and tested (-47V and 30ma@).
I'm thinkin' OT, but am I missing anything?
Here's what I know.
