I am having similar issues with the bias voltage being too low as in this post: http://music-electronics-forum.com/t31531/
This amp came in with one blown 6V6 and running very hot. I replaced the tubes and haven't been able to get the bias current down. It's running at close to 100% plate dissipation. In the 30-t there is a 47 ohm resistor that regulates the ac voltage available. I am going to replace it to get the neg voltage up a bit. Right now, the a/c voltage is at 34vac and my bias voltage is at -42v with the trim pot all the way down. My only concern is that the 18v power supply feeds off the same circuit. What is the max voltage that I can allow on that circuit?
There is also a note in the schematic ("bias mod") that says there is a 47K resistor off the wiper leg of the trim pot that this amp doesn't have.
jmf-spectra-120-amplifier-schematic.pdf
