Dear Fury, you are testing "parts", I want to test "function", not the same.
I think Enzo will understand what I'm pointing at.
FWIW *so far* I suspect good caps and rectifier, go figure.
Please
And please check what I asked in post #13.
The point is that some of those measurements *look* dumb, as in: " I have 10 volts on one end of this wire, I certainly *must* have 10V on the other end, 4 inches away, why measure again?".
Well, they often are "dumb", but now and then one is not what you assumed.
This leads to a "WTF ????" moment which then may lead to an answer.
Please
put the caps back on the board and the power supply board back into the amp and see what happens.
