Hello Folks,
After working on a couple vintage Traynors and falling in love with their tone, I recently purchased a 1972 Traynor YGM-3 for myself
The amp is in pristine condition and ALL original including the filter caps, jan-phillips tubes, etc. For sure I will be changing the 2-prong to a 3-prong power cord for safety reasons but am unsure if I should do other service as well.
Basically the amp is dead quiet, works perfect, and sounds absolutely wonderful as is with its original (Mallory) filter can caps and coupling caps. Should I re-cap it based solely on its age even if its working great?
Also these amps are notorious for putting ~35-38ma on the EL84s with the stock fixed bias. On the other ones I serviced I put in a bias pot and biased new tubes at a more normal 21ma. Should I do that also or just let it be until I re-tube at some point?
The question is: Should I "fix" it if it isn't necessarily broken?
Thanks for your thoughts
