Hi Guys,
I just had a friend bring me his SVT-II Pro to take a look at. He's had it at several shops and nobody has ever been able to correct the issue, so now I'm getting a crack at it. I suspect the others didn't have the power of the ampage board behind them! A couple of questions to start.
1) Does anyone have a complete set of schematics for this? On an old post from Enzo on here, I found several of them, however a few of his uploads I wasn't able to download for some reason.
2) The amp has had all of the tubes replaced, I'm still going to re-check em, and the amp powers up and plays fine.......so what's the problem?
3) ISSUE: So there is something that I would suspect to be thermal related....after about an hour of playing the amp starts to make crackling/popping sounds...what my friends refers to as "ghosting". These can be the worst to track down as the amp normally works fine on your bench. After looking inside this thing last night, I remember why I hate to work on SVT's, let alone the modern ones. What a hassle. However, does anyone have any suggestions for me to take a look at off the bat?
I have a heat gun/freeze spray I can try to use, however with the thing packed so tightly PCB wise, I'm not sure how I'm going to get real access to it while it's working. In the past this type of thing has been a cap issue, however I'm hoping people on here who have SVT experience can point me in the right direction. Any help you can provide me, the awesome people of ampage, would be much appreciated!!
