As soon as the amp is turned on, a loud, distorted hum comes out of the speaker. Front control knobs do nothing, which makes me think it is in the power out section. This amp uses 400BH drive board and output board.
Combo300.pdf
I'm having trouble taking live readings because the noise is so loud. Is it ok to disconnect the speaker on an amp like this? I've always made sure there was a speaker connected as to not over load the output transformer but that is on a tube amp.
With the output board removed, I took readings on the power transistors pins (pins going through the board on 6357s) and they are all around 1.6 ohm except the drivers which are 7.5M to 8M.
I also took readings on the P600D diodes and found them to be very different. Forward resistance (black probe on cathode), both read .5M. However, reverse resistance (black probe on anode), one reads 35M, the other only 15.5M. Not sure if this is the problem or not.
I've got a lot to learn but I sure love this stuff. Thanks for any help.![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
PS: also, someone modified this amp with a switch on the speaker out jack as to bypass the internal speaker and redirect to an external speaker only.
Combo300.pdf
