Saturn GA-45RVT Low Power
  • Saturn GA-45RVT Low Power
    MOTHA*&^%$$ just typed out a long post and it crashed adding schem
    Anyway, Gibson Saturn GA-45RVT, 6L6 with broken pin installed wrong, blew fuse and 470 Ohm screen.
    Replaced resistors and output tubes for testing.
    Amp works, all features but only a few watts output.
    V5A stage doesn't amplify, is it supposed to or just a phase splitter?
    Also voltage on V5 pin 5 only 30v instead of 60v.
    Amp varies greatly from schem between V4 and V5A, output pins 6 & 7 tied together, and instead of a mixing circuit theres an odd attenuator similiar in design to the schem, but different values.
    Jumping across from V4 to V5A with a cap and amp puts out rated power.
    Info:
    All voltages close to schem value except V5 pin 5
    No hum noise, minor ripple, so filter caps look decent.
    Tone stacks really kill signal between stages, I guess the idea was to amplify signal to power amp with the 6FQ7.
    Amp also has a few of those crappy caps used in Thomas Vox amp that need to go!
    Ugh, here's schem
      Nobody really familiar with these?
        Any one of the caps, C13-C16, could be leaking & throwing off the Vdc & the signal voltage.
        C14 &/ or C16 would be my first thought.
          V5A is [cathode-biased] cathodyne phase splitter. It's a (practically) unity-gain stage feeding the 6FQ7 gain stage/drivers. Yes, yes. This thread may be old, but not as old as those filter caps...input to a bootstrapped phase splitter such as this will be a VERY high-z node, so a multimeter reading will be affected by the meter loading...
