Trying to determine if the toroid is bad or not in a 2002 Ampeg SVT-3 Pro, the question is about the secondary taps. I got it as "non-working, not worth repair expense". The toroid is one of the most expensive bits so I thought I would verify it first. No power has been applied.
Schem shows the following secondary taps order: Red(6) to Grn(2) is a winding, then Grn(4) to Red(1) is the next winding. (The number in parenthesis is the plug pin.)The pcb ties both Grns, (2) & (4), to ground. The Reds are each rectified to supply +/- 100vdc.
The taps pull from the toroid in exactly that order i.e. (6) (2) (4) (1), and they insert into the plug as numbered.
When I check continuity via the plug however, I read .4 ohms from Red(6) to Grn(4), and .4 ohms from Grn(2) to Red(1) and no continuity (6) to (2) or (4) to (1), or (2) to (4).
So not knowing how windings are created/tapped on a toroid, I'm wondering if one winding is supposed to be complete before the next winding begins/ends, and so on, or are the Grn leads switched in the plug or what the story is? If they are switched it won't matter to the circuit since they tie together. I'm thinking the toroid is good but don't know how else to verify without powering up.
