Over two years ago I had a customer bring me a David Eden Traveler, the 300 watt one, I forget the model number with the complaint that the amp runs for about 10 minutes and then cuts off. I checked through the amp, hooked it up to 400 watts of 4 ohm dummy load, shot a 220hz sine wave at about 300mv into the input and cranked it monitoring the output waveform on the scope. I also stuck a temperature probe on the heatsink. After a bit I could plainly see that the heatsink temperature was not stabilizing and continued to get hotter and hotter until the thermal sensor tripped and the amp went silent. I finally found that I had a failing output transistor, interestingly enough the one that the thermal sensor was attached to. I replace all 4 output transistors, reset the quiescent, did the trial by fire test again which it passed this time and sent the customer on his merry way.
2 years later he call again and says "the thing is cutting out again". This amp led a hard life constantly on tour and worked perfectly for two years and then this... I said bring it in and I will figure out whats going on here. I figured the output transistors were going bad again.
I played it for a few seconds with my trusty 5 string bass and when I hit that low B the thing sputtered and went silent, I repeated this several times and got similar results. This time however it was a flakey gassy old 7025 preamp tube, so I replace that and did my trial by fire test as I did before and everything looked great, the temperature stabilized somewhere around 150F and the amp never cutout so I figured problem solved. I played it for about an hour just to make sure, called the customer up to pick it up and he was off again to beat the amp to death just as he likes to do.
A few days later I got a call from him... you guessed it, it's cutting out again. This time I had him bring in his whole rig from the pedal board all the way to the speaker cabinet plus all his cables and I went through it all in great detail. I could find nothing wrong, aside from that I could not replicate the failure in the shop no matter how hard or long I drove the amp. He took the amp back and called me a few days later and said it's working great, thanks!
Here comes the punch line... Two weeks later he calls me and says, "it's cutting out"!!!
Any ideas out there???
