Hi There,
I have a Traynor YGM-2 that I'm having some problems with. This amp runs on 2 EL84s, which I currently have pulled. I am not seeing any negative supply voltage to pin 2 which I believe should show around -20VDC.
Here's the voltages that I'm getting with the tremolo Intensity and Speed at 0:
Pin 1 : not connected
Pin 2 : when I first turn it on it reads -3VDC then it slowly goes down to 0
Pin 3 : 0
Pin 4 : 3.3VAC
Pin 5 : 3.3VAC
Pin 6 : Not connected
Pin 7 : 450VDC
Pin 8 : not connected
Pin 9 : 450VDC
Any help would be great. Thanks!
Pin 3 : 0
Pin 4 : 3.3VAC
Pin 5 : 3.3VAC
Pin 7 : 450VDC
Pin 9 : 450VDC
