Hello folks,
I have a BDR amp with noise problem. Not hum and hiss. A lot like pop sound.
There are some tests I have made:
1. The pop sound is not always heard. Sometimes it happened in 10 or 15 mins.
But sometimes it happened just at turning off the standby. Sometimes the noise will gone itself.
2. The pop sound happened only in the clean channel. The noise stopped after switching the drive channel.
3. The noise won't gain by increasing amp volume knob. But the noise level will decrease by turn the treble knob down. The noise seems happened with/without signal input.
4. The preamp tubes (V1, V2, V3) have swap to new ones. The noise still happened.
5. When the pop sound happened, I insert the guitar cable plug to the return jack. The noise is gone.
The amp sounds good.
6. Use stick knock the tubes or PCB units, Nothing happened. The connect wire is good.
After reading the schematic, I guess It's a relay problem. After installing new relay K1, K2 , The noise is still.
I also replace the new cap C33, C35, C36. Nothing better.
I use oscilloscope see the waveform. When the noise happen. The waveform after C53 is getting little distortion. But I don't know where is the problem.
Hope someone can give me some advice. Thank you.
SeeEmilyPlay
SeeEmilyPlay
