I am trying to get the tremolo working on a Peavey Classic amp. I had original thought it might be a bad sps-953 because when I first checked the circuit all the voltages were jumping around. I did replace the faulty sps-953 (replaced with 2n6520) and all the voltages in the circuit are now stable. Still my tremolo circuit is not working and has the same symptom. Also, to note that I have ruled out that the sps-690 as being faulty and have put a 2n4249 to replace. I have also changed SPF-576 to a 2n5461, but realizing it was not the problem put the old one back. All the parts were looked up as reliable replacements using the Peavey transistor cross reference guide. Also, have to say that every electrolytic cap was replaced as well. Tube drivers replaced, new multican filter cap and the amp sounds great, just no tremolo.
So the symptom occurs when you turn up the depth pot for the tremolo and the volume of the amp goes to zero. Just as if it is shunting the signal to ground much like a backwards master volume pot. Now I did some signal tracing and signal reaches the pot and (obviously) connects through the pot. As I turn up the pot, signal can be traced on the input to the pot and is not effected when I turn it up. However, after the pot the signal goes away as the pot is increased. So, I tested the pot and even took it apart to have a close look at the wipers. It all looks fine and has me stumped. I am not using a footswitch but I believe the tremolo should work without the foot switch. I have been reading up on the way that JFETs work and I understand that it is used for switching purposes.
The depth pot passes signal to the JFET SPF-576 on the Source leg of the transistor. I measured the idle voltage of the 576 S=5mvDC D=.7mvDc G=.9mvDC. Another thought about the SPF-576 is that it is not marked as that in the peavey transistor guide. Actually the only one in there that made sense was SPS-576, so I took that as the type I have here in this amp. I guess it could be a bad part and the 2n5461 is really not the right cross reference for this JFET. New one did not change the behavior so I put the old one back. I did test both with meters and the old one appears to be fine.
I am posting the schematic and a picture of the schematic with my notes. I am thinking that something is not right in the circuit(obviously), but just can't seem to track it down. On the schematic there is reading that says .6vDC connecting to the base of sps-953 and I get 7.5vDC on my circuit. Looking at the schematic it might really say 6volts and the .6 could be a dot on the copy. But if that base is supposed to be .6vdc then I think that is my problem. The caps could be leaky or something else. Check my picture for added comments. I hope someone can help cuz I am scratching my head right now.
