I'm having a problem with my Fender Acoustasonic SFX II. I have very limited electronics knowledgeable - but it seems like it may be an easy fix with the right guidance.
The amp works and sounds fine on both channels, but about every 3 or 4 minutes it will cut completely out for about 2 seconds, then come back on and function fine for another few minutes. This happens on both channels. I've tried different guitars and cables to eliminate those as the culprit - I'm sure it's the amp. The power light stays steady when this happens - I haven't opened it up yet, but I was wondering if anyone has heard of this problem before or know what could be causing the problem.
Thanks for any tips or advice.
Also, any idea where I could get a schematic for this amp?
Thanks
Joe
Thanks
Joe
