Hi all,
Been a long time since I posted but I haven't been away (just out of sight). After rebuilding a '73 Twin Reverb I've completed all sorts of other projects and recently build my first amp from scratch (a 5e3 Tweed). I must admit I couldn't have done it without the ton of information that I found on this site. Thank you all for sharing your knowledge with the rookies like myself.
Although there is a lot of information available, there is a problem I can't find the answer for. My '73 (100w) Twin I rebuild to AB763 specs is working perfectly and I'm loving the tone, there is only one problem. When I turn the reverb past 8, out of nowhere a incredibly loud and low pitched rumble occurs. It seems like it feedbacks only difference is, it is a low pitched tone. The sound is suddenly there and (very loud) doesn't slowly swell up. I tried different reverb cans and swapped tubes (to no avail). Is there a point where I should start looking? Maybe the Reverb coupling caps? I build the the circuit on a turretboard using orange drops and f&t caps.
Thanks!
Thanks!
