Mesa 2:90 power amp channel B weak output and distorted. I have swapped power tube sets and output trannies between channels with no change. Problem stays on ch B. All voltages ok with schematic on power, preamp and driver tubes.
Mesa 2:90 power amp channel B distorted
Is this the schematic you are using?Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
If that's the right schematic, then it sounds like you're talking V1a (12ax7 input).
Have you checked the cathode cap, and metered the resistors around the tube?"Stand back, I'm holding a calculator." - chinrest
That IS the correct schematic, g-one. Thanks for posting it. I have checked every component around the tube, even comparing reading with the other half components. I replaced a 4.7k that was barely out of tolerance. No change. Everything seems absolutely perfect on the preamp circuit. Any idea on how to unhook the presence circuit? Presence control doesn't seem to be working. Kind of hard to tell with the distorted signal.
Originally posted by jvm View PostI have checked every component around the tube, even comparing reading with the other half components.
Your original complaint suggested that you'd isolated distortion to the V1a gain stage. If that's the case, then after verifying that the tube and control resistors are OK, I'd replace the cap and measure the old one. Ck is cheap and time is valuable. I'd also rule out the coupling caps as being a problem.
If the sound of the amp is ambiguous to you because you're listening by ear, or you're scoping with a monotonic frequency generator, try sweeping the input. That should tell you very clearly if there's a frequency response problem and if the NFB/presence circuit is functioning."Stand back, I'm holding a calculator." - chinrest
What I meant is that all preamp components test as good. I also replaced the cathode cap with no change. I would like to rule out the LDR but have only VTL5C4's on hand. The amp uses a VTL5C9. Can I get away with the 5C4 in just a switching circuit?
Unless it's a royal pain, I would swap parts between the good and bad side (for stuff you don't have like the opto).
And you should be checking all your measurements against the good side, Mesa schematics can be different from the actual units.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
