Sovtek 6L6WXT
  • Sovtek 6L6WXT
    I am working on a 1996 Fender Hot Rod Deluxe and when I put these tubes into the amp I could only get the bias down to 95mV when following the bias procedure on the schematic. Put in a pair of JJ's and the bias came right in without issue. I didn't use a bias probe since I was in a bit of a rush. Why the issue with the Sovtek's when trying to set bias?
    Have you tried more than one pair of the Sovtek's? Is it a matched pair? Maybe try one at a time and see if one is running hotter than the other when using the same bias setting. I'm guessing one of them is bad?
      but that's right at 70%, leave it there
        From the 6L6WXT's I have installed it appears that they do bias up hot.
        You need a real good range to get them down.
          It may be 70% but the factory setting is for 60mV, not 95mV. It will definitely reduce the lifespan of the tubes, which would not be fair to the customer without approval.
          casinolevant levant casino
