What I have is about a 2003 Randall RH200 G3 head. This one has the toroidal transformer.
I have this strange noise when the gain2 control is turned up past 8. I know any hi gain amp is going to be somewhat noisy however this is different. It almost sounds like what you would hear thru a phone if you dialed a fax number. I have some decent electronic skills so I’m no stranger to it but do lack a full or complete understanding of how some of it works. So if you get too technical with me I would look at you as if you were wearing a Viking helmet….OO
Here is what I have done so far. I have cleaned and lubed all of the pots and switches. I cleaned and checked all ground connections, checked them for continuity. I have replaced the input, line out, and return jack (that was necessary). I plugged my guitar into the return jack and all was perfectly quiet so I do not believe there is an issue on that board. I also was getting the noise thru headphones.
I realize most of you guys frown upon these amps and I don’t blame you. After seeing what lack of support there is out there it will be the last for me. All I want to do is repair it if possible and give it to my son.
I hope someone here can offer some insight and help guide me thru this.
