might also replace R1/2/3/4 and c1 while the board is out....one of those could be causing all the noise ?
Weird feedback---Crate
I've lost track a bit, originally there was oscillation but now there is static, correct?
Is it in both clean and drive channels?
When on clean, does turning down the volume get rid of the noise?
Have you tried a jumper from R1/R2 junction to ground? Does it make the noise stop?
If not, lift one end of C9, this will remove OC1 when on clean channel.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
