My NRI / Conar 224 tube tester suddenly began sending every 12AX7 tube to the bottom of the red zone, even ones which showed 'good' on previous tests . I haven't tested any other tubes since this happened, it just seemed like something was amiss and every test would be suspect. For a while before it began doing the "instant" deep six, it would occasionally dip into the red zone then climb well into the green when "TEST" was pushed.
I know these are just basic emission testers and aren't the end-all/be all but it helps a bit at a reasonable cost. So I'm wondering, could the issue be something as simple as cleaning the contacts on the "TEST" button or is possibly something more serious? Where would I start looking?
I wanted to ask before peeking under the hood...perhaps there is some other maintenance I should do?
