ANOTHER dead valvestate !
  • #61
    e / b /c
    tr4 -35 / -34 / -35
    tr7 +26 / +41 / +41
    • #62
      Um...
      How can you have +26 on the emitter of TR7, with +41 on the other two TR7 is an MPSA56. Looking at the flat front face, the legs are left to right E-B-C. I am made to think EITHER you are reading the legs in the wrong order, OR the transistor is in backwards. ANy possibility of that?
      The fact you have about -35 on all three sides of TR4, and +23 or more on all the legs of TR7 tells me that the circuit through TR9 is either open or the transistor is not conducting. Oh wait, TR9 is missing?
      • #63
        they are on the board right--maybe i read them backwards...emitter and collector .
        yes TR9 is out of the pcb right now
        • #64
          TR9 & 10 are out of circuit.
          You really should complete the path.
          1K resistor on TR9 & 10 base to emitter connections should do it.
          • #65
            The way that TR7 & TR4 are biased, they should barely be On.
            Meaning the collector voltages of both should be very, very low.
            • #66
              ok--ill try installing the 1k res tonight and report back---thanks !
              • #67
                ok...
                tr8 still in.....9 and 10 out . 1k res installed as said.
                readings b / c /e
                tr8 +26v / +41 / +40
                tr9 holes +10 / +26 / +5
                tr10 +6 / -41 / +40
                • #68
                  TR7 & TR 4 are most likely bad.
                  • #69
                    put the 2 chips in , replaced tr4 / tr7 .
                    powered on with the limiter in place = still has a short-no change
                    • #70
                      So what changed?
                      Before the most recent parts replacement (TR7 & 4) you had the amp off of the limiter.
                      Correct?
                      And you had the 1K resistors installed (to prove out the voltages)
                      And you did not have a short.
                      Personally, I don't know why you reinstalled the output transistors, as of yet.
                      The last go round showed a very high voltage on the bases.
                      Not good.
                      What gets me is where is the current going.
                      There is not a load hooked up is there?
                      You have to get off the lamp limiter.
