So the original thread was getting long and the blown fuse issue was resolved thanks to everyone.
NOW, when the amp is turned on with volume on zero there is super loud and horrible crackle through the speaker, so loud it will blow it if not shut off
OK.
-Triple checked all wiring and solder work (actually the amp was working ok last night but only played it for a minute)
-Still have stable voltages at +/1 51vDC with no blowing fuses
-Getting .04v DC on the speaker jack tip
-Amp is pulling normal with no speaker hooked up (dim bulb) but pulls hard with speaker plugged in (bright bulb)
What now? give up on it?
OK.
