Fender Super Champ X2 smoking resisitor
How did you test C41?
There is a short in the inverter node of the power supply. C41 would be the obvious part to cause this, but there could be other causes. Check for shorted connections and or pc board traces, etc.
With the amp off and the caps discharged take a resistance reading from TP31 to ground. What reading do you get?
The readings don't make any sense to me, where did the earlier 298 ohms go? Is the voltage back at TP31? Was there a shorted connection on C41?
If R47 is burning and the voltage at TP31 is 3 volts dc, something is loading the circuit down. As I said before C41 is the most likely suspect, but there are other possibilities as well.
Did you replace R47? What does its' resistance read?
Originally posted by 52 Bill View PostThe readings don't make any sense to me, where did the earlier 298 ohms go? Is the voltage back at TP31? Was there a shorted connection on C41?
Possibly the cap WAS leaky and R79 has also gone towards open? Check the resistor R79. Also check the voltage on both sides of R47 and see if it is indeed still dropping all of that voltage indicating a short down line or if there is low voltage on the supply side of it. You may have only solved part of your problem."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
