Hello
I have a little 15 watt amp using a Matchless DC30 preamp which has been working well for a while - until last night. I decided to put a 12AT7 in the PI, (which was untested) to see if I could clean it up a bit.
And then, I powered it up and forgot to hook up my speaker for about 5 minutes. Oops...
Once I plugged the speaker in and started playing, I noticed A) a large decrease in headroom, and B) the sound was sort of fading in and out a bit - not on and off, but definite volume fluctuations.
I then put the 12ax7 back in the PI (noticing that the 12AT7 was VERY hot), and this seems to have resolved the volume fluctuation thing, but it still flat out does not sound right. Distorting more than it did previously - in a bad way - is the primary symptom.
I also then noticed that the 12ax7 in the PI was red plating.
I don't see anything in the way of visual inspection. Nothing smells or looks burned.
Can anyone help me with where to start my troubleshooting without doing more damage??
Thanks in advance.
Greg
Thanks in advance.
Greg
