fender frontman 212 distorted output
  • #31
    Haven't replaced Q9 or 10,
    Is there a good sub I can use, I have lots of transistors but no 2362s I believe
    but looking
    • #32
      For whatever reason, they used a high voltage part.
      120V C to B.
      The pinout is E C B looking at the flat face.
      http://81.233.9.161:800/_pdf/2SA/2SA1016.PDF
      • #33
        Could I get away with a low voltage sub?
        • #34
          To try?
          Certainly.
          It's working off of a +42 volt rail.
          Keep in mind the tail is ultimately connected to the -42 v rail.
          • #35
            I once rebuilt a polytone and used two 2N5210s in a similar application, a sub for Q1 an obsolete part PT1583
            Will those work here?
            • #36
              Originally posted by pontiacpete View Post
              I'm back to working on this amp. Fortunately it does not belong to a customer. After changing out U6 and the amp worked I put it under my bench with plan to post it for sale and finally get rid of it. Then one of my customers comes by I take it out to demonstrate it's wonderful sound and it's back to sounding like it hell. So I put it back under the bench with the hope of returning to it.
              The weird thing now is that I'm finding that if I touch my probe on one of the leads of the diodes in the string D21-23 the amp works correctly, distortion gone.
              If i randomly probe components around the area the distortion comes back and the bottom half of the wave goes askew. Can't seem to be able to do this on command but I can correct the problem by touching one of the diodes.
              Any one want to take a stab at this.
              Have you tried tickling components in that area with a can of freeze mist and/or a heat gun?
              • #37
                Maybe there is an oscillation that the probe placement is "curing" ?
                • #38
                  havent' tried the freeze yet
                  I was thinking there might be an oscillation, also
                  • #39
                    Hi Pete, did you ever get this resolved? I'm having almost the identical problem with my FM 212. It works OK most of the time but randomly makes a crackly sound when it feels like it and goes into a distorted output state from time to time. I have the exact same experience where I can "fix" it (until it does it again some time later) by touching touching my probe to D21 or in that vicinity. I started a new thread earlier today for it.
                    • #40
                      I'm sorry to say that I haven't yet figured this one out. I have the chassis sitting at the end of my bench vertically for the longest time. I've been following a recent thread about this amp with the hope that I'm might get some insight as to the problem.
                      Yes, it was weird that it would work fine until touching a probe around in that same vicinity. But now I"m getting very little sound out of it.
                      I was tracing a signal the other day and found that I could see a signal into the power amp but haven't gotten much further.
                      I hope you can find something to help me out.
                      • #41
                        Can you send me a link to the recent thread you mentioned?
                        • #42
                          here ya go,
                          https://music-electronics-forum.com/...ad.php?t=49822
                          • #43
                            Thanks, Pete!
