Hi, really struggling with my new build..sloclone..got a loud 50hz hummmmm picked up somewhere.
All voltage looks great..a little lower than stated in the schematic, but okay.
The hum increase with gain and master volume. There is no difference except from volume when switching between Clean and OD channel..the hum is rock steady.
Pulling V1 and V2 doesn't affect the hum but grounding the shielded wire at V3 grid kills the hum!
Going through FX return sounds sweet with no hum
Got 10pcs 12ax7's (5 brand new) and have tried them all as V5, V4, V3, V2, V1..no improvements!
I've attached some pics of the amp..don't mind the extras..all is wired completely like the official layout..I think.
6.3v CT winding are elevated
5v winding is used for the switching circuit - grounded at chassis
The circuit ground looks like the official layout:
Pots are grounded on the buss
Input is grounded on the same buss
Ground buss goes to the preamp board and back to the PS board
Bias pots (I use individual bias pots) are grounded at preamp board
One wire goes from the PS board to the chassis (PT nut)
HV center tap goes to the same PT nut
Power amp cathodes goes to the same PT log
All jacks are isolated from chassis (verified!)
Any help on this one??
Best regards
Thomas
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
Best regards
Thomas
