I am looking at a Peavey Valve King VK100 head. It's original problem was that it's output would fade in and out when on. I chopsticked around the inside with it powered up and had a couple loud "pops" near one of the preamp tubes and the sound would fade then, so after draining the caps I touched all the connections near the preamp tubes with a hot soldering iron.
That didn't help. As a matter of fact, the amp won't make any sound at all any more. Now the tubes won't light up. I don't have any heaters at the preamp or power tubes. I measure 0 VDC at pin 2 and 35 VDC at pin 7 of the power amp tubes.
I am unsure if the original problem was the heaters.
I have the schematic, which I got from Peavey. I am having a hard time deciphering it as it has no voltages listed.
What should I be looking at here? Where on the schematic does the heater voltage originate from?
Thanks in advance for taking a look. The schematic is attached below.
peavey_valveking_100_212.pdf
