Originally posted by g-one
View Post
So I Blackfaced the Twin ,and I have a few issues.
Originally posted by gtrplayr1976 View PostHi folks,
I decided to blackface this twin. I removed the MV wiring ,and changed MOST of the amp to AB763 specs except the reverb ,and vibrato caps ,and resistors (cathode bypass ?)wired to the pedal jacks. I removed everything else that wasn't on the AB763 ,and added/changed values as indicated. I also changed the filter cap feeding the choke to a 40uf. When I first took it off standby there was a bit of a pop. That is no longer there ,but there is a sizzle for a second of two. All controls at zero it sounds like the amp is on. I can hear sound through the speaker. The thing that really bothers me is that when I was checking voltages on the preamp plates pin one was silent ,and voltage seemed normal. Pin six had really loud hum ,but voltage seemed normal. I got the same thing on V1,V2,and V4 pin six very loud hum. Also noticed when I increased the intensity pot there is static like a leaking cap. Other than that it sounds pretty good. What did I miss ? Here are the preamp voltages I took. Thanks for any input !
1 2 3 6 7 8
V1: 272 0 2 286 0 2
V2: 270 0 2 281 0 2
V3: 456 0 8 456 0 8
V4: 289 0 2 294 0 2
V5: 461 -52 0 411 -52 0
V6: 312 43 74 305 46 74Last edited by supawah; 02-06-2014, 10:51 PM.
Originally posted by Zouto View PostDid you check the 470 Ohms PI cathode resistor? I saw some sort of blackfaced "broken" Twins with 470K or 4K7 Ohms etc. mistakenly used. Otherwise, checking all the ground connections thoroughly is always a good idea.
I replaced the 470 Ohm resistor with a new one as well as replaced the 22k resistor to 33k. I got the cathode voltage back up 121. I know that's higher than the 100 spec. I may have to change another resistor. I still have this very loud humming even when I get near any of the XY,Z jumpers. The layout shows where the hum is located. V6 pin 2 had very loud hum ,and bias went wacko when I put the test lead on it. The others marked with H ,or LH also had hum . When I got near any of those with a test lead you can hear the hum swell.
1 2 3 6 7 8
V1 : 264 0 2 268H 0 2
V2: 260 0 2 273H 0 2
V3: 441 0H 7 441 0H 7
V4: 270 0H 0 282 0LH 0
V5: 436 -52 0 282 -53 0
V6: 272 72 121 272 78 121
Node B: 443
Node C: 432
Node D: 399
XY,and Z 0 volts ,and hum
Originally posted by Jazz P Bass View PostThankyou.
