Peavey Musician III with the 400GH power amp buzzes when speaker is connected and no output.
Initially used light bulb limiter to power up, but it DOES NOT blow fuses, so now have it connected to full line voltage with a 6.25A fuse installed for testing purposes. Stock fuse is 8A.
Anything else to check while I'm in here? Is it a good idea to install fresh 5000/55 and 100/35 electrolytics while I have the board out?
- Line voltage = 122.6 VAC
- Measured 1.2 mVDC on MAIN speaker output jack
- Measured ~38.2 VAC on main power rails (schematic indicates +52)
- Both 1A fuses are good
- ~38.2 VAC at anodes of CR9 and CR11 - both diodes test good
- ~16.6 VAC at anodes of CR8 and CR10 - both diodes test bad
- R39 and R40 are dropping voltage
- Measure -26.6 VDC at C36, 0 VDC DC leakage across C36, tests fine for ESR
- Measure 26.5 VDC at C37, 0 VDC leakage across C37, tests fine for ESR
