Hi all,
I was so pleased with my (now fanned) LC15R as described in other threads that I did go and buy another one. This is a 2004 model and looks a bit better built - this time I was pleased to find no SMDs inside. I had some valve trouble (broke/replaced an EL84) but the amp sounds and plays OK; did a gig or two with it.
However ... it has a case of singing to itself when set to about mid gain and volume - it sounds like a clear high pitched sound same as mike feedback, independent of input or reverb but dependent on all the other knob settings, particularly gain and vol. It is not mechanical, though any chassy knocks are amplified but I guess that is normal. I have resoldered, swapped valves - same thing.
The amp is usable, but you have to watch that fb all the time and though it plays loud you can't really turn it up full wack
One thing I noticed is that my other amp has a sticky gooey foil patch over the preamp part of the pcb while this one hasn't - but looks like that is by design.
Does anyone have any ideas?
Next I think I will disconnect and short P3 and P4 (this will turn it into a LC15 no R) and see if it makes a difference.
