Hello.
I've been restoring/refurbishing my old Ampeg G20 which has long been one of my favorite amps. It fell into serious disrepair about 10 years ago & I finally got around to dealing with it. I'm so close to done that I can taste it but I have a behavior in the power section that I really can't explain. I don't _think_ it's normal but I wanted to get a sanity check & some advice on what to look at if it's not normal.
Here's a schematic for the amp. Not the best quality but it's what I've been working off of. http://www.turretboards.com/layouts_.../ampeg_g20.gif
It' a fixed bias amp & has no adjustment pot or current sense resistors at the moment. The bias voltage is about -60 which seems to scale with the other internal voltages that are also higher than listed on the schematic due to my ~125-128 VAC line voltage.
Signal coming out of the PI look clean and stable. All the coupling caps are brand new. This doesn't seem to be affected by how much signal I pump into it.
I shot some video & one still picture of the scope traces with one channel hooked to the plate of each 6L6. Notice how the trace "dances". I've endlessly tweaked the holdoff on the scope to get it this good but I can never get a stable trace. I have a still on my ipad that I'll post separately that shows what I get with the holdoff on auto. It's not pretty.
Video #1. Channel 1 of the scope attached to the plate of one output valve. Amp issue scope channel 1 - YouTube
Video #2. Channel 2. Amp issue scope channel 2 - YouTube
Video #3. Both channels in differential mode. Both channels in differential mode - YouTube
Anyway, I would deeply appreciate any insight into what I'm seeing. There is a little bit of harshness on the sound and I do not know if these crazy scope traces and the harshness are related and therefore I am not sure what direction to go in solving it. Being a PCB amp it's going to be kind of a pain to add bias adjustment hardware (I already converted it off of the 7199 PI & did not enjoy cutting traces) so if this behavior is something other than a biasing issue (or if it's absolutely normal which I would love further explanation of...) I would like to weed that out now. If bias adjustment is the ticket then I'll gladly go there.
Finally, I really enjoy reading this forum & hope to be able to contribute something useful at some point.
thank you so much
thank you so much
