Woe is me! I've been working on a Hiwatt DR103 clone from Tilo Zotolla's book on building tube amps. I had some biasing problems but I worked those out with help from Amp Kat on this here forum. Well...None of the tone pots were working at all and the bright volume pot was all messed up as well. I was taking some voltage readings on each tube tonight and I had higher than normal DC readings on the 3rd and 4th 12ax7s. The 3.15 AC pins measured right on. I could hear a pop each time I took a measurement. However, then all of a sudden I started getting zeros on all of the DC pins of each 12ax7. No voltage whatsoever...and no popping sound when the probe of my multimeter hit the pins. Now the amp will make no sound at all. Does anyone know what might be causing this?
