I recently needed to replace a reverb pan for a friend's amp, so I bought one of the MOD brand pans.
I really like how they configure their input & output jacks. I purchased the 4EB2C1B pan because it was the closest I could get to the original, but the original had the input jack tied to the pan & the output jack was isolated. This pan is the reverse, but the clever way they use to "ground" or isolate the jack from the pan allows you to convert it to whatever configuration you need. If you look closely at the pics, you'll see that the PCB trace has 2 breaks in it that you can solder bridge to complete the circuit to ground the jack or leave it open to isolate the jack. They even put 2 breaks in the trace so that you don't have to solder under the wire once it is in place.
