2 layered 5-way rotary switch needed
  • 2 layered 5-way rotary switch needed
    Hello,
    For a project I need a 5-way rotary switch with 2 poles in the center and 2 layers of that, so I can switch 2 independent functions without the 2 layers interfering with eachother.
    For example 1 layer could switch between resistor values, the 2nd layer between cap values while I rotate the positions.
    What is such a switch called please? Thanks
    "Tubes are less likely than semiconductor devices to be destroyed by the electromagnetic pulse produced by nuclear explosions and geomagnetic storms produced by giant solar flares."
    2 pole 5 position rotary selector switch.
    There's tons of them from China, on ebay.
    5 position selector switch | eBay
      Originally posted by kka View Post
      For a project I need a 5-way rotary switch with 2 poles in the center and 2 layers of that...
      I don't understand what you mean by "layers". Do you mean 2 poles 5 position X2?
      If you mean two- 2 pole 5 position switches in one unit, then you need a 4 pole 5 position rotary switch.
        These are selected as "number of decks=2" "number of poles per deck=2" "number of positions=5"
        http://www.mouser.com/Electromechani...z0x3mhZ1z0x3s5
          I ordered some of these rotaries from tayda - Rotary Switch - Switches, Key Pad - Electromechanical - and was surprised to find that a switch I was installing had fewer positions than I was expecting. Then I realized that the switch chassis had a bunch of holes in its surface around the middle shaft, and one of the washers that came with the switch had a little tab that fit into those holes. The number of positions it would switch to was determined by where you positioned the washer tab, such that a 2p6T could be a 2p5T if you wanted.
