I'm working on a 1960 Fender Concert amp. Somewhere along the line someone replaced (among other things) all 6 diodes in the rectifier string. On one leg, one of the diodes is reversed. It's the last one where the two side meet. The amp has been working apparently. I will, of course, replace the diode. What problems can or could this have caused? I'm kind of surprised it works so well.....
Backwards Power Supply Diode
Originally posted by Daver View PostI'm working on a 1960 Fender Concert amp. Somewhere along the line someone replaced (among other things) all 6 diodes in the rectifier string. On one leg, one of the diodes is reversed. It's the last one where the two side meet. The amp has been working apparently. I will, of course, replace the diode. What problems can or could this have caused? I'm kind of surprised it works so well.....
I would meter test the backwards diode to be sure that it is in fact in backwards and not just marked differently. Also measure the dc before and after the replacement and see what happens to the voltage levels.
Thanks, guys. I tested the diode and it's marked correctly so it was in backwards. I didn't measure the B+ before replacing it. I was in too much of a hurry to make it right. One of the problems and complaints about the amp was that it was really bright and somewhat thin sounding. It does sound better now. Guess that had something to do with it.
