Happy NEW YEARS!!!!!!
Firstly, make sure the pot shaft is actually moving. Sometimes they seize and the knob just rotates. Take off the knob and check it will move.
If this is OK then check the solder joints on the back of the pot. It's most likely that there's a problem with the connection where the 270pf treble feed cap attaches - it's a small ceramic disc on the circuit board. A wire could have come off, or there's a bad solder joint. If you think the cap has gone open, tack a replacement in parallel - anything near enough will do to test.
Another possibility is that the pot lug has come loose where it's crimped to make contact with the track. They can be squeezed up with pliers to get you by.
If you haven't worked on a tube amp before you need to familiarize yourself with the hazards and safe working practice.
