Marshall 1959SLP Low Bias readings. Help !
  • Marshall 1959SLP Low Bias readings. Help !
    Hello from Italy, I have a problem with my 1959SLP Head
    All seem OK but I can't reach the correct bias values with VR1
    I can reach max 20mA on each EL34, and this is too low.
    I checked the tubes, filter caps, bias supply, grid resistences, catode to ground. All seems OK.
    The palte voltage is 455 Volts and the bias on the grid is -45 Volts
    I hope that you can give me some suggestion.
    Thanks,
    Nye
    See if R28 is a 56k resistor and try changing that to 33k I think that will drop the current but it may be the other way but I think that is the resistor.
    KB
