I have one of these amps on my bench right now and I pretty sure that there is a short between emitter/base on one of the 3155 transistors. Basically, I still need to pull the part out to test it out of circuit. Just wondering if anyone can provide a good substitute for a 3155? Searching for this part I have not really come across any data sheets to help source the part. Also, it would be a long shot but does anyone have a copy of the schematic for this amp? I did see a schematic for sale on musicparts, but pretty sure the client might not want to spend $15. Thanks.
Edit: Another question is regard to the amp having an output transformer. Do I need to worry about not having a load on the amp? I have not worked on a solid state amp that had an OT on the output section. I basically have followed the policy to not connect solid state amp to a load until no DC is on the output. Will this philosphy apply even if it has a an OT?
