Just got a 5150 with no output.
all fuses are good inside
all tubes lit up
there is 500v to the output tubes , but no high voltage to the preamp tube board. Not even at the other end of the 4 ribbon cables
also the standby light is out...yet i have 500v to the power tubes.
running another amp in / out of the fx jacks = no sound either way .
cant find anything burnt or loose
the schematic i have is somewhat complicated (to me)--im trying to find a board layout to help
where would i start looking for the missing pre-tubes voltage ? There are 3 large electrolytics under the ribbon cables to the pre pcb, one being 47uf/500v....none of them have voltage
and shouldnt the amp work going into the return jack if i have power at my power tubes ?
all tubes lit up
