You have no bias at C41, then you won;t have bias anywhere else either. Is your meter set for DC volts?
Bias doesn;t care about standby, it is always there.
C43, C42 ought to have bias voltage on them, so do they? Is the bias fuse OK? You MUST remove it from its clip and check with a meter.
