Hello, I have a Peavey TNT-100 that I purchased in 1982, yep and oldie, I just pulled it up from the crawlspace where it's been resting for the past 12 or so years. When I put it away it was working fine.
Now when I turn it on it has a loud nasty hum with nothing plugged in to it. Gain knobs make no difference in the sound level either.
I dug around and found two different schematics for it. One has IC's on the schematic the other does not. My unit has IC's on the board.
I disconnected the speaker to try to troubleshoot and found that one of the output transistors gets hot as an iron and the other one stays cool. I metered the outputs of the rectifier diodes and I get ~16v on two and ~21v on the other two. I figure this difference is because of the problem.
I could use some help on this guys. I've had electronics training, WAY back when this unit was new. Problem is I've forgotten a lot. I believe with some help I can get this animal working again. I don't have a scope but have a meter and plenty of other tools.
None of the caps appear to be blown.
Any recommendations on where to start? I sure could use some advice here. I have an account on Mouser so getting parts shouldn't be a problem.
Thanks
Greg
Thanks
Greg
