Hi. Just inherited this Crate amp, made in St. Louis. It works well on Clean and switches to Rhythm channel okay via front, but no solo channel. Rhythm/Solo switch tests okay. Also, will not switch between clean/rhythm via foot switch, although the switch tests fine on other amps and LED lights up. No measurable signal to the foot switch and no LED.
I have the schematic and have tested Q5, Q11, Q15 and Q23 at my friend's suggestion and they test to spec on Mouser website on the board. No visual indication of heat damage or bad solders, although Q9 loos like it may have been re-soldered at some point. Anyone have an idea of what else I should be looking for? My expertise is in computers, but I have a very fundamental understanding of electronics, a good meter/ IC tester and can solder a board.
Thanks in advance for any suggestions
