You have control signals A,B,C etc they come from page 2. Ther is a chart on that page called Switching Logic. That tells you the voltages on the control lines for each state. Start there, are ALL those A, B, etc control voltages toggling as you flip switches?
yes, ther is an LED for Solo.
If all the control voltages are being made on page 2, then see if they are reaching the JFETs like Q29, Q2, etc.
On all the op amp ICs, pin 8 has +15, pin 4 has -15.
JFETs are normally ON, with a lowish resistance between source and drain. I expect something like 100-200 ohms. A voltage on the gate turns it OFF, meaning a very high resistance between source and drain. Thus us acts as a switch controlled by the gate. If you get gate voltage going off and on with the channel selecting, then measure resistance from source to drain. Do this while the amp is RUNNING, otherwise there is no gate voltage. Your ohm mater may make the amp pop. Does the resistance source to drain =go high and low with the gate voltage switching on and off?
