Thought I'd post this...Had this amp for repair and the complaint was that when the tube gain knob was adjusted, the unit would make lots of crackling and popping noises...(tubes had already been replaced).....Removed the front PC board and checked for broken solder connections and the shape of the pot...Found a bunch of solder connections on some of the controls that were kind of bad....fixed them up....same problem.....Downloaded a schematic and noticed that the tube gain pot actually varies the plate voltage to two tubes....a 12AX7a and a 12AU7.....but there was a 12AX7 in the 12AU7's location.,,,Changed that out....problem was really weird as it sounded like a bad connection because when you tapped the boards while you were varying this control the amp would make all kinds of strange noises for a few seconds and then settle down....once it settled down you couldn't get the amp to act up until you varied this tube gain control......I removed the power supply/output board and did a good visual inspection..I noticed a dis-colored section on the circuit board which could not be seen from the top due to the natural color of the circuit board itself and the large amounts of silicone present....There were two 16 volt zener diodes there for the low voltage supplies along with two 220 ohm 10W resistors and two 47uf 25V caps....The diodes tested fine and I even put a heat gun on them to see if they went haywire when heated up...the only thing that happened was the forward voltage drop would decrease with applied heat.....and I checked out a few other diodes that I had just to be sure....I did the same with the resistors and they didn't budge from their rated value......however, I did notice that there were poor solder connections to the leads of these resistors...I cleaned up the leads and the pads and then checked the two caps...They are installed between these two power resistors and looked as if they had the outside insulation shrinking on the cap..Tested these and they were out of spec but not by very much...Giving them a quick shot of cold spray would cause the capacitive rating to drop....So I replaced those with 100uf 35v caps for better filtering......Also soldered some bad connections to some jacks and connectors.....Re-installed the board and connected everything back up and tried it out...Worked fantastic....So I am thinking the two power resistors with the bad connections were probably the main cause and it is possible that some of the other bad connections might have also played a part in some way...I replaced the caps based on the fact that they were not up to par, the unit would probably be back, and I would have to tear it apart again...but I don't think the caps were actually the root cause...I think the bad solder connections on the two resistors were.....but you had to look real close....at first glance they were not noticeable....Hopefully this helps somebody out in the future......
Cheers,
Bernie
Cheers,
Bernie
