Hi Folks
I have one of the above in that makes a loud thump when channel switching. Couldn't get a schematic from them but managed to get one for the EL84 version which is very similar.
From that I see it has a jfet mute transistor on the input to the Tube section that should mute it while the relays change so I think its not doing what it says on the tin!
Holding that Jfet on does infact stop the pop, but it doesnt work in normal operation.
Looking at the schematic the FET is turned on by a pnp transistor and is turned off by a RC pair charging to -33Volts (theres a 4M7 between this and the gate).
Looking back further I cant actually work out how the pnp is turned on! Its controlled by the outputs of a sort of flip-flop cct I think but I dont see how it does it.
I've gone throught all the components but can't find anything duff. I have no way to monitor the pulse since I dont have a storage scope.
Anyone familiar with these amps? If so I'd appreciate some thoughts!
The guys also asked me if I can reduce the amount of gain increase when the boost is engaged! Now theres another issue I gotta get my head round, another circuit I've not seen before!
Cheers
Shane
Cheers
Shane
